96 355 Aft - Kohler Gen not firing up!
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: 96 355 Aft - Kohler Gen not firing up!
Post by buster53 »
Jfriz wrote:Hey Sailor Jerry...... if it acts like it’s running out of fuel I’d certainly replace the anti syphon valve as mentioned earlier.
Yes, do replace that but it wouldn't hurt to check/replace your fuel filter as well
Been thanked: 1115 times
Also, check the hose connections and the seals on the fuel filters. If there's any leak (even if it doesn't leak out gas) it will suck in air because the fuel pump has to develop enough vacuum to overcome the anti-siphon valve. If your fuel filter is empty, that's a clue you've been sucking air and it's been getting in somewhere.
