Kohler 7.3E Won't Start
- jsurfwhite
- Vessel Info: 2000 Carver 356 Aft Deck
- Has thanked: 12 times
- Been thanked: 4 times
- KeithS
- Vessel Info: 2005 38SS
- Been thanked: 23 times
Re: Kohler 7.3E Won't Start
- Has thanked: 324 times
- Been thanked: 595 times
- jsurfwhite
- KeithS
There is a vacuum assisted choke pull off that sometimes gets sticky from corrosion, but to check that you would need to remove that black cover. The issue then becomes trying to reassemble properly because there is a bi-metal spring that has to engage a slot just right.
The proper way according to Kohler would be to remove the whole front cover assembly and adjust the choke with a 1/8" gap open when cold. Easier to use the trial and error 1/4" at a time method.
- jsurfwhite
- KeithS
- jsurfwhite
Users browsing this forum: No registered users and 46 guests
