Borg Warner trans leak
Been thanked: 1117 times
Re: Borg Warner trans leak
Capn Crunch wrote:QR_BBPOST
bud37 wrote:QR_BBPOST It is quite easy to tell the difference when seen in the boat.
having always owned stern drives I wouldn't know a V-drive if it bit me... any chance you can point me to some pics somewhere showing the difference? The boat we're looking at is a 310... the occasions I've had to look in the bilge appeared to have a gear box underneath the motor, not at either end?
The easiest way to tell if it has a V-drive is to look at the engine. If the "front" on the engine is facing the "rear" of the boat, then there must be a V drive in there to turn things around.
Capn Crunch
Vessel Info: 1995 Carver Santego 310
Crusader 350XL injected, Hurth Inboard
Location: On the Mighty Columbia River in the Pacific Northwest
Has thanked: 87 times
Been thanked: 7 times
Post by Capn Crunch »
km1125 wrote:QR_BBPOST The easiest way to tell if it has a V-drive is to look at the engine. If the "front" on the engine is facing the "rear" of the boat, then there must be a V drive in there to turn things around.
Thanks km, I did determine earlier today V-drive of the Hurth (360A I believe, 1.5/1?) persuasion... looks like one unit - transmission/v-drive - combined. Hoping this unit is not one of the "fragile" ones.
