Engine Replacement
- Has thanked: 56 times
- Been thanked: 441 times
Re: Engine Replacement
- Has thanked: 457 times
- Been thanked: 1689 times
A couple of questions:
Is there a lot of blue smoke when you first start her up after sitting overnight and then it subsides?
Does the blue smoke continue for as long as you run the engine or just at startup?
Is there blue smoke regardless whether it's at 800 or 2000 RPM?
Are you noticing a performance issue; rough idle, etc,?
Most important; have you had an oil change recently, was the proper grade oil used, AND is your engine oil at the proper lever?
As for the number of hours, while they're a starting point, the only thing it tells you is how long the ignition system has been energized. On older engines some of that could be from just leaving the ignition key in the ON/RUN position. Do that when you leave to go home for the week and you've added over 100 hours. What's more important is how the engine was run and maintained in the past. A very high hour engine that was well maintained and not overworked will be in best condition than a low hour engine that's been neglected and abused. The above tests with the addition of a vacuum test (if you can still find someone who knows how to interpret it) will tell you more about the engine's condition than the hour meter will.
I wouldn't repower the boat with lower horse power engines.
Is this a fresh or salt water boat? Has she ever been in salt water? You should add your location to your personal info, it helps.
I haven't done it in a boat, but did on many car engines back in the day. It's not hard at all.
- Has thanked: 585 times
- Been thanked: 1228 times
Let's see what the compression tests bring, I agree with the leak down, that would be my choice of diagnosis.
The pcv valve check is good as a bad one can cause pressure issues, they are cheap enough , but it is important to get the right one for the engine.
- Cooler
- Has thanked: 68 times
- Been thanked: 398 times
Users browsing this forum: No registered users and 58 guests
