Manuel says spark plug gap should be .045 the cover on top of the engine says .060? NGK BPR6EFS Any thoughts on which gap I should go with?
Cheers
2002 Carver 346 6.2 MPI spark plug gap
- Been thanked: 1312 times
Re: 2002 Carver 346 6.2 MPI spark plug gap
That is confusing for sure......Are both the cover and manual referring to the same NGK plug or any brand ?
- Pha8
- Vessel Info: 2002 Carver 346
- Has thanked: 32 times
- Been thanked: 5 times
The cover lists AC, but the manuel lists AC (same plug) ,NGK, or Champion.
If it were me and the engines were performing just fine , I would just replace the plugs with the same make and range of what is already in there. You can check the gaps and the burn etc when you take the old plugs out, they will be close enough to get the idea what gap and range is working for your engines and the way you use them.
Personally I would just stick around .045" or so for the standard type plugs and that ignition type......IMO
- Pha8
I decided to go with 0.045
I would have replaced them with the AC's that were in there before, but I had already bought NGK's so I try them with that gap and see how she runs. Thanks for the replies.
Cheers
Cheers
