exhaust outlet for generator
scoobychonx
Vessel Info: 1991 carver 36 aft cabin twin cummins
Has thanked: 5 times
Post by scoobychonx »
Hi can anyone tell me where there generator exhaust exits. Just trying to find the best position. Regards lee
After Taxes
Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada
Has thanked: 6 times
Been thanked: 17 times
Post by After Taxes »
Doing a new install?
MerCruiser MX 6.2
Lake Simcoe, Ontario
scoobychonx
Yes it's a new install and just wanting to get ideas. Regards
Out either side or the stern. I'd say in a new install, out either side is likely the easiest as you don't have to try and run the exhaust hose through the aft cabin. Are you doing this yourself or hiring someone? A lot of things to consider.
scoobychonx
Hi thanks for the info. I'm going to fit it myself as I'm an engineer
CYO Admin
CYO Administrator
CYO Administrator
Has thanked: 269 times
Been thanked: 29 times
Post by CYO Admin »
Look into doing an underwater exhaust system. You'll thank me later :)
scoobychonx
Does the underwater exhaust system make a big difference in silencing
CYO Admin
CYO Administrator
CYO Administrator
Post by CYO Admin »
scoobychonx wrote:QR_BBPOST Does the underwater exhaust system make a big difference in silencing
Yes it does. The water is discharged under the water line and the exhaust is above the water line. Makes a big difference in the noise level.
scoobychonx wrote:QR_BBPOST Hi thanks for the info. I'm going to fit it myself as I'm an engineer
Will this be a new or used marine unit, and do you have full installation instructions for that model?
