Afternoon everyone
Hope everyone is enjoying the boating season
My oil pressure gauge (port) keeps jumping up and down which makes me think its the oil pressure sensor. I can't seem to find the part number in any of my manuals.
I tried calling Diesel Parts Direct and gave them my engine serial number but no luck.
Anyone know know where or how to get the part number?
Kuya
2000 Carver 506 - 6CTA Cummins - Oil Pressure Sensor
- KuyaJunGarage
- Been thanked: 3 times
- Been thanked: 1312 times
Re: 2000 Carver 506 - 6CTA Cummins - Oil Pressure Sensor
Heh there, can't help with the # for you ,maybe you have..... but before you condemn the sender maybe check the wiring connection there for corrosion also the connection to ground thru the sender itself. Good luck man I hope someone has a number for you.
Ya I would check the wiring first, looks corroded, that could give you inconsistent readings.
- KuyaJunGarage
Morning, BUD37 & Viper, thanks for the reply and suggestion. Will try this, awesome thank you guys.
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 149 times
Try www.sbmar.com
They are pretty much the go-to source for all things Cummins. Especially check out "Tony's Tips" to really get to know your engine.
Good luck!
Good luck!
MV Verity
2002 Carver 396
2002 Carver 396
