Prop scan scheduled for Carver 405
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Re: Prop scan scheduled for Carver 405
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Has thanked: 457 times
- Been thanked: 1687 times
You'll need a short stand of some sort to get the dial up to the higher part of the shaft where there is typically nothing to clamp a dial on to. While you have the props off, try to dial the taper of the shaft. It may be a challenge if you can't get a usable surface with no key-way. If not, try to get a clear area by the threads that the dial probe can ride on. Easier to dial the shaft with the prop on and use the prop to turn the shaft. With the prop off, you can use a rubber strap wrench to turn the shaft or insert the key and use an adjustable wrench against the key to turn the shaft. Make sure you clean the areas you're going to dial before proceeding.
Lyndon670 wrote:Source of the post If no vibrations and running smoothly....remind me again why we are checking runout of the shafts?...
I guess one could say that what you don't know won't hurt you but we all know that's not true. Just because you can't feel anything, doesn't mean everything is okay. The way I see it, your running gear is mechanically connected to your tranny and your engine, if not turning true, it's common sense to expect higher than normal stress on bearings, seals, etc. For the little effort it takes as a new owner or if you've had the vessel for a while and just never thought of checking this while on land, I think its a healthy practice, vibration or not. Sometimes with the engines running and the vessel underway, it's not always easy to pick up a minor running gear problem. And when you're new to a boat, you have no baseline for its feel or sounds, so it can be assumed that what you feel and the sounds you hear are normal for that vessel. I rest much easier knowing my gear is running smoothly as measured rather than relying on whether I can hear/feel it or not.
- dsolo
454 EFI Crusaders
Dan
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Lyndon670
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Vessel Info: 2007 Carver 41 CMY D6 370's
- Has thanked: 1 time
- Been thanked: 3 times
Lyndon670 wrote:Source of the post Also, be advised that there is a method to reinstalling the prop. It is not just a matter of silding the prop on the shaft and over the key way. You have to lap the shaft with lapping compound so that the prop sits properly in its taper. There is a method for lapping a shaft. You may want to further investigate this before attempting this if you have never done it.
Correct me if I am wrong but I thought lapping was only required when new or if the prop and/or shaft was replaced and now required to be lapped (adjusted) once more. As an example, a damaged prop removed for repair and reinstalled does not require lapping.
As for a puller on a 4 blade. I used a standard 2 leg bearing puller with a battery operated impact wrench. Took no time at all to remove both props. Puller looked like this. http://www.ebay.com/itm/2-Jaw-Puller-3- ... 7~&vxp=mtr
- Has thanked: 583 times
- Been thanked: 1226 times
- Lyndon670
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Users browsing this forum: No registered users and 54 guests
