Optional inverter on Carver 405 "97"
dsolo
Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll
Has thanked: 68 times
Been thanked: 25 times
Re: Optional inverter on Carver 405 "97"
Postby dsolo » May 8th, 2017, 2:35 am
Tom,
I may have a Kenwood set to donate also. I will most likely replace it with an updated media player. All our audio is digital, Pandora, or Sirius. I just haven't decided which equipment to go with? Home or automotive?
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » May 8th, 2017, 12:29 pm
I went with a kicker KMC-10 mounted on the helm. Also added 4 kicker 6.5" speakers 10" kicker subwoofer and kicker 700.5 amp. Added a remote on aft deck.
Also have Sirius.
Sounds like live concert if you turn it up. crystal clear at all volume levels.
Postby tomschauer » May 8th, 2017, 12:34 pm
[image][/image]
Postby tomschauer » May 8th, 2017, 12:37 pm
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » May 15th, 2017, 2:18 pm
Not sure my budget is there for your system? :cry: :cry: I sure would like to copy it. I am sure it sounds wonderful.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Has thanked: 270 times
Been thanked: 1160 times
Postby Midnightsun » May 15th, 2017, 3:12 pm
Another great option is the Fusion line which is comparable with nema 2000 protocol used by Raymarine and Garmin so basically it turns tor plotter into a full function remote control.
Been thanked: 622 times
Postby g36 » May 17th, 2017, 11:34 am
Fusion also nmea 2000 with lowrance hds systems which is what I use for my electronics
pikaman
Vessel Info: Carver 390, 1993, CPMY, twin crusaders, full awning model.
Been thanked: 6 times
Postby pikaman » May 24th, 2017, 12:43 pm
hi all
we have a 390 circa 1993 and our inverter is located under the galley counter on the inside of the bulkhead atthe lower right hand side of the fridge. A little hard to get at through the door under the cutlery drawer, but there is tons or room in there. not sure if it is original equipment but it is an 1800 watt unit.
Have a look and see if yours is there.
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » May 27th, 2017, 6:21 am
We have searched. No converter on board. Both stereos are 12vdc. No sure what we will do? At the moment we just want to enjoy the boat as is.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Return to “Electrical”
