3807 Aft Deck Refrigerator and ice make replacement
VapinBill
Vessel Info: New owner of a 1989 3807.
Has thanked: 8 times
Post by VapinBill »
Good day all.
We need to replace both the refrigerator and icemaker on our Aft deck of our 3807.
Does anyone have dimensions and model replacements for both? Also need to know if I could find these items at an RV supply store.
1989 3807 Carver Aft Cabin
Twin, Crusader 7.4L (454 cid V-8)
Detroit Michigan
Been thanked: 248 times
Re: 3807 Aft Deck Refrigerator and ice make replacement
Post by mjk1040 »
Check out Edgestar, I replaced our icemaker on our 1998 355 with one, a little cabinet trimming and it went right in, A lot less expensive than marine and rv models.
VapinBill
Post by VapinBill »
Thanks, Mike. I was hoping someone had the cutout measurements for the 3807 already. I plan on taking both the fridge and ice maker out and measuring them myself this weekend.
Detroit Michigan
Post by mjk1040 »
Being ur units are 28 years old, I doubt the marine brand replacements will not be the same measurements. Good time to re-plumb with pex and sharkbite fittings. Good Luck!
Post by tomschauer »
Hey Mike, what edgestar model did you use? Does it stay really cold 36 or less? My icemaker still works like a champ after I replaced the cube tray last year, but I would have more beneficial use from a refrigerator.
Post by mjk1040 »
Tom; I replaced the ice maker with and ice maker not a fridge. You would have to check the model specs on their fridges to see if they would fit.
VapinBill
Post by VapinBill »
Called Marquis and got the following info for replacements:
The refrigerator replacement model is: Norcold 07-0179.
The ice maker replacement mode is: Bi95FCB-30A
Already replaced pvc with pex and sharkbite cutoff valves
For the freezer and wet bar faucet.
There was plumbing behind wall panel in main salon.
Detroit Michigan
