Fuel Sender/FLoat Leaking
ronmar
Vessel Info: 1993 350 Aft Cabin
Has thanked: 21 times
Post by ronmar »
I have been getting fuel smells in my boat, and replacing fuel fill hoses and vent hoses. In the process I found my fuel sender/floats are leaking on port and starboard sides. Cannot seem to find replacements. There are numbers on top flange that are 175 2614 and are 17 1/2" long. The gauges are VDO dual station. Anyone know where to get replacements? :banghead:
Boat is 1 93 350 Aft Cabin
Re: Fuel Sender/FLoat Leaking
Is there a gasket there which could be replaced....make new one and reseal.....
ronmar
Post by ronmar »
Thought of that but they have not been working like they should, I've already got the accesses all removed from changing new hoses, and vents, and the senders are right where I'm working. Might as well replace while I'm there and don't have to tear things apart again. (ounce of prevention). However, having issues finding replacements. Did come across Moeller #035767-10.I think is same gauge and is correct length. Description does not say if compatible with a dual station or not. I don't know if there is a difference between dual station and single station as to the sender.
Post by Midnightsun »
I would give VDO a shout with a model number to see what resistance your particular gauge uses in order to change the sender. Seems like VDO made a bunch of different stuff. Any sender will work if you match the resistance and appropriated depth of tank. https://www.vdo-instruments.com/instrum ... /fuel.html
ronmar wrote:Qr Bbpost I don't know if there is a difference between dual station and single station as to the sender.
I believe there is, if two stations make sure what you get the sender that is ok for that use, same with single..there is usually a stipulation on the unit.
It's critical that you find out the resistance window of the gauge before you get a sender. Typically the senders are single station, really depends on how your application is wired. You should be able to find out from Carver the part number and supplier. From there it's just a matter of finding someone that carries it. Having said that, if they are working and you're just trying to stop them from leaking, there are sender gaskets on the market. As long as yours are the standard 5 hole pattern, they should work. Do you know if they're leaking through the gasket or the screws? You could seal both with a fuel rated gasket sealant and also put some on the screws, just try not to get any on the inside of the tank. AND ventilate when you're working down there...no sparks please :-O
Bentone23
454 xli TBI Crusaders
Has thanked: 57 times
Been thanked: 5 times
Post by Bentone23 »
I have fuel smells too. I might be checking that now.
Bruce Bennett
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
Been thanked: 1114 times
If it's a dual station, so you have momentary switches so that one gauge is for both tanks, and you use the switch to set which tank the gauge is indicating?
That's how mine is, so essentially only one gauge is hooked up at any given time even though I have dual stations, so I would use a single-station sender if I had to replace it.
