1987 3607 blower question
RWS
Vessel Info: 1987 3607 aft
Has thanked: 28 times
Post by RWS »
1987 3607, did it come with 1 or 2 blowers? My boat has 2 and if you turn on from the bridge and then also turn on lower helm switch it sounds like they either sped up or the 2nd one comes on. Are they wired separate or does turning on lower helm switch also push more electrical current to them and increase their speed? Some things will drive you crazy about a boat.
BenTen
Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
Has thanked: 20 times
Been thanked: 32 times
Re: 1987 3607 blower question
Post by BenTen »
I don't know about your boat specifically, but have you tried looking at the wiring diagram from Carver? I'm sure they are still available. It sounds like someone changed the wiring or you have some corrosion in the wire from one of the switches (higher resistance = less current and more heat).
Thanks,
Ben in SC
Been thanked: 1114 times
There are two blowers and they both come on at the same time with either the lower station switch or the bridge switch.
What you are hearing is the difference in voltage drop. With both switches on you are essentially doubling up the wire going to the blowers which cuts the resistance in half, allowing a slightly higher voltage to run the blower. It is normal.
RWS
Post by RWS »
km1125 wrote:QR_BBPOST There are two blowers and they both come on at the same time with either the lower station switch or the bridge switch.
Is it hard on the blower motor to have both on?
RWS wrote:QR_BBPOST
No, not at all. The motors are cooled by the flowing air. More current make more heat but also more air moving though to take care of it.
