1999 35' Carver Aft Cabin Rub Rail
Asset Allocation
Vessel Info: 1999 356 Carver Aft Cabin Motor Yacht
Post by Asset Allocation »
I need to replace a section of the rubber and metal rub rail on my starboard side. I called TACO but apparently they didn't supply CARVER with rub rails. I'd like to get the same brand as what Carver installed but I'm finding it challenging to find an exact match.
Any help is greatly appreciated!
Asset Allocation
Re: 1999 35' Carver Aft Cabin Rub Rail
Woops meant to say Port side not starboard.
Ramsport47
Been thanked: 59 times
Post by Ramsport47 »
Give Bret a call at Carver (Marquis Yachts) with your hull number. He can tell you who made it and where you can obtain it.
Kenny
T-Merc 350 Mag MPI (300hp)
Asset Allocation
Thank you so much Ramsport 47!
Asset Allocation
Is there a specific location I should be looking for Marquis Yachts?
Post by g36 »
try this
Carver Yachts Parts dept. 920-822-3214 ask for Bret Temple
please post what you find out
thanks
Ramsport47
You can also use btemple@marquisyachts.com. He is out of the office until Monday.
Kenny
Asset Allocation
Update to what I found out. I called Bret and the rubber portion was $7.65/ft and the metal piece is $5.64/ft. He's going to mail it out. Hopefully, I'll have the results of a successful installation to post on the board for everyone.
CYO Admin
CYO Administrator
CYO Administrator
Has thanked: 269 times
Been thanked: 29 times
Post by CYO Admin »
Great!. Please do post pics!
