454 CI carburetor question
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 38 times
- Been thanked: 11 times
Thanks,
Vic
- Has thanked: 579 times
- Been thanked: 1210 times
Re: 454 CI carburetor question
Just my opinion...
- VicB
- Been thanked: 1043 times
Look at that pivot pin in the center of the divorced choke thermostat. Make sure it is not loose. Mine were loose and would cause erratic choke operation. Once I re-crimped them, they worked just fine. Make sure you clean the manifold where they bolt down to also, as you want good heat transfer there. There is an exhaust passage through the intake manifold right below the divorced choke thermostat, which heats the area. Your engine temp doesn't have to be very high but the choke will open up because of this exhaust passage.
The choke should snap shut when the engine is cold and should fully open when warmed up. However, there is also a choke pull-off diaphragm that pulls the choke open just a bit once the engine starts. It has a small vacuum line to it that may be faulty, or the diaphragm might be faulty. You can use a small vacuum pump the check these. They would be mounted on the carb just forward of the divorced choke linkage.
- VicB
Maybe get an IR temp gun and double check those temps at the thermostat housing.
- Has thanked: 324 times
- Been thanked: 595 times
- VicB
- mjk1040
- Been thanked: 242 times
Users browsing this forum: No registered users and 46 guests
