Not Going Into Forward Gear
Been thanked: 470 times
Re: Not Going Into Forward Gear
Post by RGrew176 »
Keep us posted and when you solve the issue share the solution here. We can all learn from your experience.
Trying to help you but we still don't have clarification on whether you are an inboard or sterndrive application. Which set up do you have, the ones in the first or second link in my post above?
Been thanked: 1114 times
Could be something as simple as a loose cable attachment or even a stretched cable. Did you compare the linkages on the port and stbd motors to see how their shifting setup compares?
I looked at the spec sheet for that 89, 32' Mariner....looks like it only comes one way, with inboards, if that is the case then it will be v drive, not sure if remote or not.
vgcapano
Vessel Info: 1989 Carver Mariner 32
Twin 350 Mercruiser 5.7L Motors
2001 Seadoo Challenger 2000
1994 Sea Ray Sea Raider (sold)
Post by vgcapano »
After a lot of digging and having someone look at it, the packing was all destroyed for both forward and reverse. The transmission was removed and rebuilt $1700 later. Thank you all for your responses.
