Gas transfer from aft tank to port/starboard tanks
- dkoons16
- Has thanked: 10 times
D & D
- Has thanked: 324 times
- Been thanked: 595 times
Re: Gas transfer from aft tank to port/starboard tanks
Turn the selector so the pointer, not the handle points at the tank description you wish to run that particular engine from.
The Aux, is your aft tank.
- Been thanked: 615 times
- Johnnykey
- Vessel Info: 98' Carver 405
- Has thanked: 27 times
- Been thanked: 18 times
Hmmm. . . .
- Has thanked: 269 times
- Been thanked: 1153 times
- buster53
- Been thanked: 262 times
- Has thanked: 456 times
- Been thanked: 1671 times
tomschauer wrote:Source of the post The fuel transfer option is only available on diesel boats.
+1
- Been thanked: 1043 times
buster53 wrote:Source of the post Anytime I go somewhere, I run both engines on the aft (aux) tank to get there and run on my side tanks coming back home. Not only do I "rotate" my fuel, but I lighten the weight in the aft as I'm running.
That's a good plan so you don't end up with gas sitting in that aft tank. I'd only fill it if it was going on a trip and needed/wanted the extra range.
Users browsing this forum: No registered users and 133 guests
