WINTERIZATION...the "W" word
Re: WINTERIZATION...the "W" word
You don't have to warm up the engine first. You'll still get AF into a cold empty block with the t-stat in place. Like you said though, if in doubt and it makes you feel better, pull a plug afterwards to check for AF.
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Post by tonyiiiafl »
When I had RWC engines, I drained, took temp sensor out and filled block, Then drained and filled again.. Thhe did same to manifolds. ALWAYS poke about with a coat hanger wire to make sure rust doesn’t block passages.
