Before I submit to the $110/hour mechanic at the marina solution, I would greatly appreciate some feed back on this. Please excuse the length of the following.
My 2001 350 mariner has the batteries set up as follows.
The battery switch in the salon safety breaker panel has 3 positions 1, 2, and Both. According to the Carver documentation the battery selected will supply power for starting and house and will be charged by the alternators when running. They recommend alternating the batteries between 1 and 2 and that Both should only be used when one of the batteries cannot start the engines.
I recently replaced battery 2 (Group 31 deep cycle / starting) with 4 Trojan T105 6 volt arranged in a series / parallel arrangement.
After re-connecting everything and testing the voltages etc. I have the following situation.
Battery Switch in Position 1.
House OK.
Port Engine Start OK.
Starboard Engine no crank but the alarms and fuel pump run with key in the run position
Battery Switch in Position 2 or Both.
Everything is good both engines start and house is supplied.
Each battery has 2 negatives connected that go to various locations on the engines etc... very hard to track. My suspicion is that I may have upset this when i re connected things back up.
Thanks in advance for any thoughts or suggestions.
Fraser
Carver 350 Mariner Battery 1... 2..... Both
- Been thanked: 1312 times
Re: Carver 350 Mariner Battery 1... 2..... Both
Howdy....I don't see any reason why you cannot have the two engines connected together ground wise....check with multi meter for continuity between port and stbd engines, maybe they are already connected....if not that may explain the difference between 1 and 2,both...I have a big cable joining both of ours together....maybe I am wrong but just an idea......Mike
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Sounds like a prior owner made some mods. Yes all grounds should be common. You may have to trace the starter cables back to the bat switch. Both engines are normally connected to the common switch terminal.
..Aaron
..Aaron
'99 404 CPMY
SeaDragon
SeaDragon
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Aaron,
I assume you are referring to Positive cables from the starter to the switch. I guess I will have to pull the panel in the Salon and take a look. I hope the wires are tagged
Former 2001 350 Mariner owner
- After Taxes
- Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada - Location: Lake Simcoe Marina
- Has thanked: 6 times
- Been thanked: 17 times
If able, post some photos of the set up.
Use the full editor page, and add photos as attachments.
MerCruiser MX 6.2
Lake Simcoe, Ontario
MerCruiser MX 6.2
