access shaft seal
cleifels11
Has thanked: 4 times
access shaft seal
Postby cleifels11 » January 6th, 2021, 8:26 pm
Can anyone tell me how to access the starboard shaft seal on a 1996 Carver 355?
tgmkwill
Vessel Info: 1997 355 Carver Aft
Been thanked: 3 times
Re: access shaft seal
Postby tgmkwill » January 7th, 2021, 5:07 am
If you are talking about the rudder shaft, you have to take the nightstand cabinet next to bed completely apart, including the frame from the wall.
If you are talking accessing the prop shaft packing there is across by removing the bottom step going down into the aft bedroom or top step, I can't remember which one,
Been thanked: 615 times
Postby g36 » January 9th, 2021, 4:48 pm
Neither one is going to be easy sounds like
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » January 9th, 2021, 9:14 pm
Ya I can't remember the vintages but some aft cabin stairs come off and some don't. It's easier access through the stairs. The other way I can remember if you don't have removable stairs is lying over the engine, not fun.
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » January 9th, 2021, 10:18 pm
The aft cabin stairs on my 1998 355 are removable with a couple screws holding them in place. You have to feel around in the carpet to find them. I haven't removed them in a couple years, but I believe there are four screws. I would image a 1996 is the same.
cleifels11
Postby cleifels11 » January 11th, 2021, 3:40 pm
Thanks for the help, i thought i would have to remove the steps but before i did i thought i would ask
Postby tomschauer » January 11th, 2021, 5:08 pm
Once you find the screws, the steps lift out quite easily and give you pretty good access. Much better than the port side, crawling through the little access panel in the aft cabin!
Users browsing this forum: No registered users and 85 guests
