110ac panel 2 issue
- Mike28
- Vessel Info: 1989 32 mid cabi
- Has thanked: 3 times
110ac panel 2 issue
Last year I bought a 1989 32 Montego.
Everything worked great. We put the boat back in the water about 3 weeks ago and everything seemed to be ok... until I tried to turn the heat on.
Before flipping the A/C/heat breaker "on" I had the main breaket on panel 2 "on" and the volt gauge was reading 110 volts. As soon as I flipped the A/C/heat breaker panel 2 went dead and I can't get it back. I run a Y splitter to the shore power inlets at the boat since my dock only has one 30 amp plug, which has not been a problem before. I tried switching the Y splitter to see if the problem moved to panel 1. The problem was still panel 2 is dead. I removed the panel and checked voltage with a meter and I have no power to panel 2.
The wiring diagram I have from Carver shows "dual shore transfer relays". My question is... wouldn't I only have those if I had a generator? I do not have a generator.
Does anyone know if there are hidden breakers somewhere? I feel like I've looked in every spot but there must be something I'm missing.
- Has thanked: 268 times
- Been thanked: 1153 times
Re: 110ac panel 2 issue
A good reminder to all with an older boat, check the wires at the inlet connection as these do go bad. Will not hurt the least to remove, cut away a couple inches and reinstall on a fresh lead. Most boat fires originate at this connection.
Welcome to the forum by they way.
- Mike28
- Been thanked: 615 times
- Cooler
- Has thanked: 68 times
- Been thanked: 390 times
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
- Has thanked: 579 times
- Been thanked: 1210 times
- buster53
- Been thanked: 261 times
g36 wrote:My 405 has breakers at the shore inlet locations also
I don’t think builders were doing those breakers back in 1989, when the OP’s boat was built.
- Has thanked: 324 times
- Been thanked: 595 times
I assume you shut off the breaker for the a/c before reconnecting the power.
If you have a single 30 amp power supply at the dock, you most likely wont be able to run the a/c and water heater at the same time.
Users browsing this forum: No registered users and 52 guests
