1997 325 Aft cabin plastic pop rivets
gwhynot
Vessel Info: 1997 325 Aft Cabin
Postby gwhynot » April 13th, 2022, 6:45 am
Good morning,
On the rear deck there are plastic panels, and they seem to be held in by a plastic pop rivet mine are corroded and some are missing any Idea where I can get them?
Thanks in advance
Has thanked: 455 times
Been thanked: 1671 times
Re: 1997 325 Aft cabin plastic pop rivets
Postby Viper » April 13th, 2022, 6:59 am
Welcome aboard.
I think this is what you need but you'll have to confirm the diameter and length. You can probably find them cheaper from a large on-line hardware supplier....
https://www.amazon.com/AP-Products-013-140-White-Plastic/dp/B002N5JA2Y/ref=sr_1_14?crid=37B7KACWYUW0W&keywords=plastic+rivets&qid=1649847350&sprefix=plastic+rivets%2Caps%2C122&sr=8-14
Has thanked: 268 times
Been thanked: 1153 times
Postby Midnightsun » April 13th, 2022, 8:55 am
Hmmm, scratching my head on that one. Regardless, there are many choices out there in plastic as well as stainless steel or aluminum. A quick search on Amazon should bring up several choices. ;-)
Been thanked: 615 times
Postby g36 » April 13th, 2022, 11:40 am
My 97 405 also uses the plastic rivets make sure you do secure the panels somehow because oem replacement panels will be impossible to find. whats used to fix youll have to try and match color. Theres posts on here about people having issues with missing panels. I have replaced some of mine with stainless screws and nuts drilled through the stainless I just don't trust the rivets.
Postby Viper » April 13th, 2022, 2:03 pm
If you want to go with plastic, here is the product I used before on a 355. Same as the Amazon one listed above but from the AP website. Again, check your size first to confirm...
https://approducts.net/product/013-140-1-plastic-rivet-white-25-pack/
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » April 13th, 2022, 9:23 pm
Viper, the ones for my 355 are 1 1/2 long. The 1" don't quite make it.
Postby Viper » April 14th, 2022, 7:04 am
These are the ones I have left over from the last job I did. Maybe it depends on the length of the plastic standoffs they used for a particular build because I'm sure I've seen a couple of different sizes. That's why I recommended checking the length first.
Users browsing this forum: No registered users and 174 guests
