Strange situation
- AlexB
- Vessel Info: 1992 Carver 33
- Has thanked: 1 time
Strange situation
I am somewhat new to boating. Had my carver for about a year.
Couple of weeks back I noticed that both of my engines under load got up to 190 degrees. To me that seems high, I read at those temperatures sea water separates and could clog risers and manifolds. Spoke to the mechanics at the marina and they said they put an IR gun on the thermostat housing and it showed 165. They think it’s the temperature senders. Problem is I don’t remember what the temperature was when I got the boat.
Any insights from this community would welcomed.
I have a 92 carver 33 with crusaders 454.
Thank you in advance.
- buster53
- Been thanked: 261 times
Re: Strange situation
Especially since it is happening to both engines, fouled bottom is the first thing I’d look at.
- Has thanked: 455 times
- Been thanked: 1671 times
- AlexB
How do I check if I picked up barnacles? Do I need to get the boat out of the water?
What should the temperature gauge be showing? I read that 175 is a good temp for these engines.
- buster53
AlexB wrote:The engines are FWC.
All depends on what thermostat you have installed. 175 is a good temp for FWC engines.
If you are in salt or brackish water, you have barnacles. You have 2 choices, either haul the boat for cleaning or hire a diver to do it. When was the last time the boat was out of the water and bottom painted?
- AlexB
- AlexB
I have an IR gun just not sure where to point it.
Thanks for all your responses.
- Has thanked: 579 times
- Been thanked: 1210 times
Those laser temp/IR guns are great for troubleshooting and quick checks while running but be sure to be fairly close, also they are not that accurate shooting shiny objects is what I have found.
- Been thanked: 1043 times
You need to compare the thermostat housing temps to the gauges at the same time. No (real) way of knowing what the comparison was if someone else just told you they took a reading and what they read on the gauges (if they even did). You need to have an idea how accurate (or not) the gauges are. It's OK if they're off a bit, you just should be aware of it.
It's entirely possible that you don't have enough cooling water flow through the system and that's why the temps climb under load. The gauges don't get less accurate, so if you're reading reasonable temps while underway but get higher temps when at higher speeds/loads that's telling you something is wrong. That could be some impellers that need to be replacing, or that you have some obstructions in either your heat exchanger or in the exhaust where the cooling water dumps in. How many hours are on the engines? Have they always been in salt? When was the last time the impellers were changed? How about the risers or elbows?
- AlexB
I will be on the boat this weekend I will measure temps all around the engine.
Users browsing this forum: Google Adsense [Bot] and 150 guests
