I found water leaking from the starboard shaft seal on my 2000 396 aft cabin. Can anyone give me an idea for the cost of replacing the shaft seal? Of course, we have to pull the boat but I want to know the fair price for the replacement. Thanks.
By the way, we temporarily stopped the leak.
Shaft seal leak August 2022.jpg[/attachment]
Shaft seal leaking - cost of replacement.
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
- Delorean6855
- Vessel Info: 2004 Mariner Three Sixty, Crusader 6.0s w/225 hours, Koehler 7_3e genset
- Been thanked: 5 times
Re: Shaft seal leaking - cost of replacement.
It cost us around 4K to replace ours on our 360 Mariner in SoCal. How old are they? They should last 10 years.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
That looks like a SureSeal. Check out Tides Marine. The parts are not expensive, the $$$ is for paying someone else to do it. FYI I did mine while in the water, just have to be quick and you will need some really big wrenches.
..Aaron
..Aaron
'99 404 CPMY
SeaDragon
SeaDragon
That really looks like a Sure Seal as mentioned. When you have it replaced, make sure to install a spare on the shaft just ahead of it for future repairs. With a spare it can be done in the water in no time. Here is a pic of mine and the spare in place on the shaft.
- Been thanked: 1114 times
Don't you have to remove the coupling on the shaft to do it? Seems like that would be the hardest part.
- tgebler
Thanks for the quick responses. The boat is a 2000 but I have owned for last 4 1/2 years. I guess it is possible they are original.
Where exactly is it leaking from? From what I can see in the pic, it doesn't look like the leak is at the shaft seal but from the cooling line/fitting instead. Or is it indeed leaking between the shaft and shaft seal and just running back? Is the housing cracked?
- AaHubb
km1125, yes you have to remove the coupling. Removing the coupling nut was the hardest part. To do it I first had to grind down the outer wall of a socket wrench to fit into the recess in the coupling.
..Aaron
..Aaron
'99 404 CPMY
SeaDragon
SeaDragon
