Bilge Fans - independent or ganged
- vtcats
- Vessel Info: 2006 46 Voyager
Volvo D9-500’s - Location: Burlington VT
- Has thanked: 2 times
- Been thanked: 5 times
Re: Bilge Fans - independent or ganged
I may have to remove the large diesel fuel hose that connects right there at the tank. It’s the main thing preventing me from getting both arms/hands into that space on the side.
Stretching and twisting and using mostly one hand goes only so far. Had to give up (for now) with one side side of the connection point still attached and one end of the bilge hose disconnected.
Mallets Bay, VT
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 121 times
- Been thanked: 120 times
The issue is that the Fan #1 circuit breaker has to carry the load of all 4 fans (because of the ganging), and it pops when all four fans are running. Any combination of 3 fans (e.g., #1, 2, 3, or #1, 2, 4, etc...always requiring #1 to be on), will run without problem.
Just to let you know what I found out about this. The fans are not ganged, each having own independent power. However the power from Fan #1 activates a relay on all of the fans to allow the master fan switch to work. So, Fan #1 needs to be on to allow any fan to be on, but not all power is running through the Fan #1 circuit.
Okay - I realize this thread is super old - but when I read through it the one question I didn't see answered was about the "4th" fan breaker tripping when all four fans are running. The OP did later state that Fan #1 is not carrying all the load as initially thought and that it was a relay that Fan #1 actuated to allow the other fans to run. Just curious if you ever determined why the "4th" fan that got turned on would trip its breaker? Thanks!
2002 Carver 396
- Has thanked: 270 times
- Been thanked: 1159 times
- KyleR
2002 Carver 396
That indicates that all four fans are working - they just can't be run at the same time.
2002 Carver 396
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 39 times
- Been thanked: 20 times
- Phrancus
- Has thanked: 16 times
- Been thanked: 133 times
- Contact:
- Crawfde
- Vessel Info: 2004 460 Voyager
- Jskhome62
- Vessel Info: 2003 360 Sport Sedan
- Has thanked: 1 time
- Been thanked: 6 times
First, I finally got around to getting all 4 bilge blowers working on my 2003 360 SS. They are ganged electrically together through the relays described here but the difference seems to be they do not come on automatically with the ignition. I have a switch at the helm and one in the main salon panel - either of which will turn on the blowers whether the ignition is on or not. And once turned on from either switch, that is the only switch that will turn them off again, no matter what I do with the other. The only thing that seems to change is the salon panel switch lights green when I turn on from there and yellow when I use the switch at the helm. This isn’t really a problem for me as I typically run the blowers before and while I’m underway, but I’m curious if this may indicate some other wiring issue?
The other question is related to the hoses connected to the blowers. The ‘inboard’ blowers on both the port and starboard are connected to hoses that go to vents on the outside of the hull - makes sense if you’re trying to exhaust the fumes in the engine bilge. The ‘outboard’ blower hoses just run forward and hang open in the front of the engine room near the forward bulkhead. So seems like maybe these are circulating air from near the intakes of the exhaust blowers forward instead of exhausting to the outside. Kind of makes sense but would think they should be connected to something external. Is this normal or has one of the prior owners disconnected something they shouldn’t have and if so, where does the open end of the hose go?
Lastly, I think I e of these posts referenced ‘a sticky’ in the electrical forum. Does this mean there are wiring diagrams posted someplace?
Appreciate any help as always.
- Has thanked: 585 times
- Been thanked: 1231 times
Jskhome62 wrote:Source of the post Hello all. Hoping this post was active recently enough to get a response to this. Doesn’t quite address what I want some help with but seems close enough.
Is your boat gas or diesel ?
- Jskhome62
