fuel gauge not working
Topic author - Scurvy Dog
- Vessel Info: 1985 carver 3207 aft cabin
- Been thanked: 622 times
Re: fuel gauge not working
If you disconnect the wire from the sender to the gauge (it may be pink) the gauge should read empty. If you now take the wire from the gauge and ground it, the gauge should read full. If nothing happens or the readings are intermittent, you need to find where that wire connects at the gauge and do the same tests, no connection to the gauge and grounded. If the gauge doesn't react properly it is bad OR the battery connection is bad/intermittent. To check that you need to measure the voltage to the meter and wiggle things (connections) to see if it fluctuates.
- 405driver
- Vessel Info: 1998 Carver 405 gas
- Has thanked: 37 times
- Been thanked: 6 times
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 467 times
It could be something as simple as a connection that needs to be cleaned. If luck is on your side that would be what is wrong. Good luck, hope you figure it out.
- 405driver
Thanks,
Lynn
