Page 2 of 3
Re: Velvet Drive chatter in neutral
Posted: April 10th, 2016, 11:21 am
Double check that. Many a tech has been fooled. Any internal engine noise back there will be transferred to and easily mistaken/assumed to be the tranny. If the sound is determined to be coming from the flex plate, again, one mustn't assume it's a failed plate, it could be an engine runability issue.
Posted: April 10th, 2016, 5:26 pm
by Dewmyster
Tom, I have a 1998 370 Voyager I purchased last October. 7.4 MPI's with 650 hrs. I backed out of the deal because of the "chatter" from the tranny. Owner had his tech look at it and he spent $7K to make it right. Nothing wrong with the tranny but the port engine needed new heads, manifolds and risers! Rough running engine will cause this. Re-sea trailed and bought it. Love the boat but only used it for 3 weeks and put it away for the winter. Hope to have her in the water for May 1st! Good luck but please do yourself a favor and follow Viper's suggestion related to a Merc Tech.
Posted: April 10th, 2016, 11:21 pm
by tomschauer
Thanks Dewmyster, I will be sure to have everything checked. If I find the problem and make the purchase I will let you all know what the problem was.
Posted: April 17th, 2016, 12:42 pm
by tomschauer
Latest update, an old salt marine mechanic says the noise is from the springs in the damper plate. He says nothing to be con
concerned about. I do not know much about these, but I do know if one of the clutch springs in and automotive clutch fails, it makes a big mess.
Any opinions?
Posted: April 17th, 2016, 6:08 pm
Ya same as I mentioned above, different English. Replace it. A little muscle needed but not that bad to do on most inboard applications. Could be a little tight in a 355 though.
Posted: April 24th, 2016, 11:33 pm
by tomschauer
To update anyone interested. We were to settle this weekend, but I am holding off due to the trans noise. I believe we are getting a great deal on this boat if it is nothing more than a flex plate but not so good if it needs a new engine. I want it repaired before purchase as I do not like to pull from the slip if I have any doubts about my equipment.
Thank you all for you input.
Posted: April 25th, 2016, 10:03 pm
Wise move. If you revisit the sale, ask for a copy of the invoice and a mechanic's description of what was done.
Posted: April 29th, 2016, 1:45 pm
by tomschauer
To all; the damper plate was replace, it had two broken springs. All seems to be fine now.
Thanks for your ideas.
Tom
Posted: April 29th, 2016, 3:31 pm
by Dewmyster
excellent news Tom. Good luck with the new vessel.
Posted: April 29th, 2016, 6:51 pm
