tomschauer wrote:Source of the post I've seen battery chargers wired to the load side of the selector switch rather than the battery side. If this is the case only the selected battery will charge.
You may want to check this out.
+1
Viper wrote:Source of the post Don't get into the habit of leaving the battery switch on "Both". As mentioned in another post, there are several pitfalls when you do this. Leaving it on "Both" at shore with the charger on defeats the purpose of the charger's ability to deal with each bank's unique charging needs which are very different from one another. By setting the switch to "Both" you combine all batteries into one bank which with some chargers may drive them crazy as you'll have more than one charge lead on the combined bank. This may shut down charging all together in some chargers.
bud37 wrote:Source of the post Thanks guys...big help....I have to check batteries to see if charger is connected directly to them or to the switch by the back door.
Cant figure out if the fridge auto swtches to 110 as soon as it sees shore power , can you leave the fridge 12v switch on all the time and fridge picks 110 when available over the battery????
Today we left it with shore 1 on with the fridge receptacle on...battery switch on both.....everything else off....so we shall see what is what by Tuesday.
Feeez we are right next to you, live right in town.One of these days I may just drive over there and you can show off your battery setup.![]()
bud37 wrote:Source of the post Cool , good to see how you put them in there, I like that..How many amp hours are the 4 in total??....we got the boat home yesterday ,everything good....figured out the fridge and battery switches, all seems ok.
I guess that broken stud would explain the charging issues......wonder why PO would not have just changed the breaker???
Viper wrote:Source of the post Yep, they must be hooked up to the battery/source side of the switch.
BTW, please tell me you hooked up a chassis ground wire of the proper rating to the new charger.
