Battery testing with new load test meter.
- Has thanked: 585 times
- Been thanked: 1232 times
Re: Battery testing with new load test meter.
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
I just read the ProNautic manual and it states sizing with a 1250. I have not installed the 1230, I must rethink this installation. I am pretty sure the AC side is sized to accommodate the 1250. The DC is not. It will require rewiring from 8ga to 6ga. I am sure fuses will need changing also. I am going to the boat tomorrow, had planned to install the batteries and charger. Looks like that won't happen.
Again bud37, thanks for pointing this out.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Has thanked: 458 times
- Been thanked: 1699 times
- Has thanked: 72 times
- Been thanked: 1055 times
When "on", it would have each start battery dedicated to loads...one to engine the other to genset, but then you can combine both to overcome a starting problem on either side. Switched to 'off' (which you really shouldn't need except for off-season or maintenance) would disco both loads from both batteries.
Is it really 2Ga or 2/0 ga wires? You might have to upsize the wire from genset battery to the switch to make sure it can handle your main engine start current.
I have a clamp meter and will watch the system while on to see how it operates ( don't have the victron yet,ran out of money), but as I have observed doing some trials at home you will probably never see the full rated amps going in the bank because as it fills the amps drop, much of the reason for the pro mariner rec of the 1250 for you....remember you have two or three banks and things running while you are trying to charge.
Check your wire length from where your charger is to the breakers, never know you may be ok......
dsolo wrote:Source of the post....I am pretty sure the AC side is sized to accommodate the 1250....
If you currently have a 30A unit installed, you'll need to check and make sure the AC wiring is 14 AWG and the breaker is 15A before you install the 50A charger. Most 30A units only required 10A breakers and 16 AWG wire. Carver may have wired for a larger charger by default but you should confirm to be safe.
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Viper wrote:Source of the postdsolo wrote:Source of the post....I am pretty sure the AC side is sized to accommodate the 1250....
Do any marine AC systems have less than 14GA wire? I didn't think that was allowed by ABYC. Do any AC systems use less than 15A breakers?
A 50A charger should only draw ~700 watts (~6.5A) , which is well within a 10 or 15A breaker.
The PronauticP 50A unit (units from 40 to 60 amp) requires a 15A breaker. For most 30A units, a 10A breaker will suffice so it's important to make sure the current wiring and circuit protection is rated to handle the higher load when moving up to a higher output charger. I mean how much trouble are we talking about here? The wire size is stamped on the cable. What may take more work is checking the breaker rating as they're usually labeled on the sides, so if it's in between two other breakers, you won't be able to see the rating unless you pull the breaker out or are lucky enough to have a rating on the toggle.
