Found this;
M-D Building Products 04267 17-Feet Storm Door and Window Replacement Weather-strip
Peel and stick, looks and works great.
Pulled out the old stuff on the rear sliding window, cleaned with alcohol, stuck the new on. I don't think you would wver get the stuff back into the rail it came out of unless you had an open end to slide it into.
Sliding Window Sweeps
- mjk1040
- Been thanked: 248 times
Re: Sliding Window Sweeps
Mike
- Been thanked: 654 times
thanks for putting this update on here. got any pic or tip for installing this? i need to look at mine i know this needs to get done
- mjk1040
I removed the windows and pull the old moe hair seals out. Then I cleaned side tracks with alcohol and stuck the new moe hair on. Do not pull out the rail the window slides on. Just like new again. I do not think you could slide in new moe hair in the track you pulled it out of unless u took the window frame apart or notched the old track to slide the old style back in again. Good luck with urs, I'm happy mine now.
Mike
- Dan1748
- Vessel Info: 1989 Carver 3607 Aft Cabin
Hello, Wondering where you got the replacement moe hair? Looks like mine has pretty much been destroyed by age and moss. The windows require herculean strength to open and close so I'm thinking new track inserts would help a lot. I'm assuming I'd have to scrape out the old grey fuzzy stuff that's there now and somehow affix new tracks with the fuzzy moe hair? Any insights appreciated.
Dan
Dan
- Dan1748
Whoops. Need to bone up on my reading skills. 04267 Didn't see that initially. Thanks
