3807 Icemaker shutoff
crquisto
Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
Been thanked: 3 times
Re: 3807 Icemaker shutoff
Post by crquisto »
I looked to pull the sink last night, but mine has a solid top section with th surround and sink built as one piece. It is attached to the base and has some kind of sealant in the joint. I have previously removed the front grill at the base of the unit but didn't see anything that led me to believe I could get to the supply line. I just don't see any attachment points or access.
crquisto
Post by crquisto »
Had a bit more time yesterday so I decided to look into this one. Turns out it was an easy fix. Just had to re-fit the white water supply line to the solenoid as the white line had a drip where it connected. One more nuisance gone. Btw, I also did some exploring and found I could pull six screws and lift the entire freezer and ice maker out. It probably weighs only 20 pounds. Behind it I found my electrics and plumbing including a shutoff for the ice maker only.
