LAUNCH
Re: LAUNCH
denpooch wrote:Qr Bbpost Bud please be sure you post your launch. We will all celebrate with you.
God Bless You my Canadian friend!
Will do sir and thank you for that ..... :beergood:
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Re: LAUNCH
Post by feeez »
Salivate.... Salivate
I am getting antsy with each passing day.... 13 C to day and warmer through the week.... we are getting there.
Cheers
Fraser
Former 2001 350 Mariner owner
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: LAUNCH
Post by Lyndon670 »
I am splashing on May 7th. Hopefully by next weekend I can get some bottom paint on. The surface temperature of the hull is still to cold to apply paint - the thermal mass of the boat is keeping it cold to the touch.
That....and I'm afraid to pull the shrink wrap off i ncase we get another dump lol...
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
feeez
Re: LAUNCH
Post by feeez »
The ground around ours is going to be like a swamp after all this melts. I also need some decent temp to compound the hull before launch. I am still hoping for a pre victoria day launch..... fingers and toes crossed.
Cheers
Fraser
Lyndon670
Volvo TAMD74EDC
Re: LAUNCH
Post by Lyndon670 »
PRE VICTORIA DAY???
I have a weekend planned with another couple on board for that weekend!!
Say it isnt so Fraser!!
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
throwback2
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Re: LAUNCH
Post by throwback2 »
Splashed my 28 Carver this morning.After checking the bilge,I hit the starter on the starboard engine and it fired right up but didn't sound as quiet as normal. I went down and checked it out. Sure enough,it wasn't pumping water.Pulled the hose off and was still full of pink antifreeze.I figured I cooked an impeller but it was fine.(Only a year old too) I tried to blow back through the hose and it was hard and then it let go and blew bubbles out the bottom of the boat. i went to put the hose back on and muddy water came out .Hooked it back up and all good.Now for the port engine; cranking....,no fuel.Pulled the flame arrrester off and acceleration pump was stuck down.I poured some gas in the bowl vent and it popped up so quick 3 pumps of the throttle and she lit right off. Heres to a great boating season !
Been thanked: 492 times
Re: LAUNCH
Post by waybomb »
They let me bring mine over to my slip.
They are still looking for the drowning victim though.
Re: LAUNCH
Post by mjk1040 »
Well it was a wonderful warm day here in NY, almost 60 degrees, so I thought might as well get her uncovered and let the rain coming in a couple days wash her down! To my surprise my bow had been hit and bent our bow pulpit railing!!! :confused: I'm thinking travel lift? I'm thinking this is going to be an interesting conversation with the marina owners and help?
feeez
Re: LAUNCH
Post by feeez »
Lyndon670 wrote:Qr Bbpost
PRE VICTORIA DAY???
Nothing but positive thoughts for you Lyndon..... it's going to happen!!!
Cheers
Fraser
Re: LAUNCH
mjk1040 wrote:Qr Bbpost.....I'm thinking travel lift?....
Unless they pulled out at a very tight angle, that would be pretty difficult to do with a travel lift unless they hit it passing by later. If it was hit with the lift, that's a close call, she could have been knocked over. Look for scratches on the rail. Another possibility is snow load. Did they install a ridge pole right to the end of the bow rail and was it supported by a leg or was it sitting on the bow rail?
