Page 2 of 2
Re: 2001 Carver 444 AC
Posted: June 5th, 2018, 4:20 pm
Check and clean all your filters/ return air intake screens etc.......
Posted: June 5th, 2018, 4:45 pm
Is your sea water pump coming on and flowing water before your compressors start? You may just have to prime the system.
Posted: June 5th, 2018, 5:03 pm
by Tomion
Thanks will check both.
Posted: June 5th, 2018, 11:35 pm
by tomschauer
Sounds like they are locking out on lack of water flow.
As others have mentioned, you may need to prime or bleed the condenser water pump. You should have water coming out of at least two through hull fittings on your 530 when the a/c pump is running.
