Carver 350 engine meter
Blake
Vessel Info: 2002 Carver 350
Has thanked: 6 times
Re: Carver 350 engine meter
Post by Blake »
Ok Bud37, I looked tonight and there is a module between the synch gauge, tach and engine hour gauge.
Since the tach works I am ruling out the sender as the cause. Thinking the module may be the cause.
Looks like there is not much you can do with that one , just replace with kind......hopefully not expensive.
Post by tomschauer »
I believe you are aware, that is the sync module. It "shouldn't" affect your hour meter, but maybe it does.
I would try disconnecting it to see if the hour meter issue goes away.
I am not sure if these modules are still available. Mine failed and I replaced it with a flowscan.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Post by pepmyster »
Interesting topic! My hour meters are dead on, but my sync gauge is all messed up, never on the ball, and my hours meters are right on . Hope you find the source thats running the meter while engine not running.
Blake wrote:QR_BBPOST Thanks!! I know it doesn’t make sense but when synch gauge works the engine hours works.
Heh there Blake , have you found the replacement part yet ? I am thinking to replace mine as well.
Post by g36 »
My oem guage on my 405 were from beede mine uses this. Yours look like it is too.
black box
https://greatlakesskipper.com/beede-boa ... 7sQAvD_BwE
That looks like the one I have , the only obvious difference is no sticker with all the info on it. The part number ......931654.... matches one of the numbers on the original....might order one and keep original as spare.
Post by g36 »
If the guages look identical my bet is it will work. You could also call beede and talk to them.
The gauge I have has two functions ( combo) in the same housing.....top is engine sync and bottom is rudder angle.
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 85 times
Been thanked: 89 times
Post by denpooch »
I have a similar issue and the same combo set up as bud37, without a module.
A couple of weeks ago, I noticed more hours on the starboard engine. I thought it was caused by something mentioned in an earlier post regarding the key in the 'on' position. I then noticed that there is a small blinking 'h' in the meter window when the engines are running (per Viper comment). I discovered that the hours were not synced because the port side is neither blinking nor registering hours. The port meter simply stopped working. The tachs seem to be accurate.
My sync indicator has never run properly, bouncing all over the place, and I wonder if this caused a short of some kind. I spoke with Beede and they sent some wiring diagrams (for a module) but I don't think it's a match for my system. I am at a standstill.
The hours are being registered on only one engine (stbd) and it will take some explaining should I decide to sell at some point in the future.
I have included photos of rear gauges, both sync and port tach.. Any suggestions would be very much appreciated.
