Fuel Starvation
Has thanked: 270 times
Been thanked: 1160 times
Re: Fuel Starvation
Postby Midnightsun » October 11th, 2018, 5:06 am
Tomion wrote:Source of the post Spoke too soon, engine shut down again today after replacing lift pump last week. Mechanic came right out and bypassed fuel selector valve and problem reoccured. Bypassed raco filter and engine ran oefectly for 45 minutes. Had replaced filter and orings last week so ordered a new Racor.
Assuming the mechanic replaced the Racor filter properly and with the correct micron size for your application first time around, it sure sounds like you have some nasties in your tank causing the filter to clog up quickly. How full was the tank when you were doing all this troubleshooting? Reason I ask is normally you will pick up lots of the bad stuff running on a very low tank level. Do you also have an engine mounted primary fuel filter?
Bentone23
Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders
Has thanked: 57 times
Been thanked: 5 times
Re: Fuel Starvation
Postby Bentone23 » November 18th, 2018, 10:04 pm
Check for crud in the tank, delaminating fuel lines, check valves, oberg strainer, racor filter and filter near carb/TBI.
Bruce Bennett
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
