Page 2 of 2
Re: Replacment vinyl stripes
Posted: September 13th, 2019, 5:19 pm
by mjk1040
Warm it with a heat gun and it should peel right off in a solid strip!
Posted: September 13th, 2019, 9:20 pm
by tomschauer
A heat gun and a plastic putty knife will most likely work better than the rubber wheel for removal of the old striping.
I suggest you try it before the wheel. I think you will find the wheel removes the stripes and deposits the residue adjacent to where the stripes where located, making clean up 2x the time.
Also most of these wheels say "not for use on plastic"
Your boat is FRP, (Fiberglass Reinforced Plastic).
Just my 2 cents.
Posted: September 13th, 2019, 10:43 pm
I've always used a heat gun, works just fine, even on old brittle striping. You may need a good glue remover, sometimes the glue comes off with the striping and sometimes it stays on the hull.
Posted: September 14th, 2019, 8:23 am
One thing to add about heat guns......if you are not used to them , be careful as they can get quite hot and you can burn the gel coat if too aggressive .....just go easy, warming is usually good enuf.
Posted: July 13th, 2022, 1:18 pm
by Bjau
I see that some have ordered stripes directly from Carver. Is that still possible and could you please give me their adress ?
Thank you
Bjau -
Posted: July 13th, 2022, 1:35 pm
Carver boats no longer exists in its previous form....bought out and out of business.
Posted: July 13th, 2022, 1:39 pm
Bjau wrote:QR_BBPOST I see that some have ordered stripes directly from Carver. Is that still possible and could you please give me their adress ?
Thank you
Bjau -
You can check with greatlakesskipper dot com. They have a lot of the OEM parts, especially from models that are no longer produced.
