air conditioner replacment
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: air conditioner replacment
Good luck. I hope you get the old unit out and the new unit in.
Since you already ordered the new unit, before you pull out the old unit, make sure you look at the drawings for the new unit, compare the water and air inlets / outlets orientation and sizes, wiring etc. to your existing unit. Try to have any required additional materials on hand while your helper is there. After he has spent a day crawling bending and twisting, you may not get him back!
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
Be sure to note the water flow of the coolant pipes, which is inlet, which is outlet. It is easier now before everything gets all jumbled up!
Capt Bob!
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat....
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
DD - I have the original manuals for my 16K unit. If you need any info, dimensions & specs, let me know. I compared the measurements to the model Hans provided the link to. They look real close, although they do measure from/to different points. The diameter of the blower output is 7". Net weight of the unit coming out is 82 lbs. New unit is lighter. Isn't it great to have sons with long arms? Make sure he wears gloves, so no slicing takes place. If splicing wires, use the correct type of connectors, no place for wire nuts. Good luck!
er
erCooler By The Lake
- Cooler
Final thought. Get your phone down there and take pics before you disconnect anything. Helps with possible confusion.
er
- Dymonddan
- Vessel Info: 1995 Caver 355 Aft Cabin
Great idea with the phone
Thanks guys for the help and suggestions
I'll go this weekend and see if I can get a head start on it and hopefully have all I need when the new unit comes in
You will be surprised how cold it will get with this unit. The newer stuff is so much more efficient not to mention quiet. You will not hear the compressor at all, only noise will be the blowing air.
As others have mentioned take a look at what you have. Pretty simple, the water circulation hose that goes to the side thru hull is obviously the out line of the AC. Hopefully the ducting used by Carver was the standard 6" round at the unit which may or may not need to be lengthened to make the connection. 110v is simply swapped into the new unit and the thermostat will probably need a new wire as they all now use a telephone jack style connection/wire. In my case since the boat is newer and the thermostat wire/connector was already the correct one.
Cooler says the new unit has a 7" air outlet. Your existing unit more than likely has a 6" outlet. One 7 x 6 sheet metal reducer needed. 7" is not a real common size, you may not find it at lowes or HD. Any HVAC supply house should have that reducer.
- Dymonddan
Hey Cooler,
That was the same code as I was getting on mine. The a/c guy that looked at mine said the fan motor 'shorted' out and burnt the board when that happened. It would not heat or cool as the fan wouldn't run. Even when I ran the self diagnostics test it showed all was well. even showed the fan running in all five speeds although it never came on and the water pump did not come on.
- Cooler
Hey all, correction to the blower size. The current unit has a 7" outlet. I do not know what the new unit would have. A 6" outlet would be for a 12,000 BTU.
er
