Page 2 of 2
Re: Starboard engine still running hot
Posted: May 10th, 2019, 11:28 am
by Helmsman
tomschauer wrote:Qr Bbpost From the picture it looks like at least half of your raw water passes are clogged. I am not sure what water you boat in, but it seems a good long flush with barnacle buster or something similar would clean this up for less $$ and time than replacing all the exchangers.
This picture was after Ridlyming the system. Ridlyming helped some. Before I Rid Lymed it I checked the water flow from the oil cooler, then from the transmission cooler (which looked worse than it does in the picture), then out of the exchanger to both risers. The port flow out of the exchanger to the riser was much slower than the starboard flow to the riser. So, the major issue is the exchangers. I could take them off, get them boiled, tested, and put back on. But, I bought two new exchangers for $675 a piece from Mr. Cool and will replace them after The 4th of July. Again, the engines are 13 years old and the exchangers may be ok, but I look at it as a maintenance item that I can do. I do plan to pull the transmission cooler first. I already have the replacement. Just have to find the time to do that. It is just in a tough place for an old guy to get to!
Posted: May 10th, 2019, 11:29 am
by Helmsman
mjk1040 wrote:Qr Bbpost Yes, your picture shows the problem, another RyLime treatment is in order with maybe a higher concentration mixture or full strength. My open cooled system wasn't over heating but producing steam. RydLime treatment cleared it up and plan on doing another treatment this season.
I am too far along! I did replace the port transmission cooler last year when it failed. So, I am assuming this one could go at any time.
Posted: May 10th, 2019, 12:23 pm
Nharrison5 wrote:Qr Bbpost I am too far along! I did replace the port transmission cooler last year when it failed. So, I am assuming this one could go at any time.
I think you are going about it the right way...there is a time limit for all mechanical parts and coolers are very important.
So I just read back and to answer your question about hoses...Without going into great detail, the rule of thumb for me has been to replace all hoses on the suction side of the raw water pump with wire reinforced hose....then on the discharge side of the raw water pump you can use the preformed hoses that fit nice.
Posted: May 11th, 2019, 6:46 am
by mjk1040
Nharrison5 wrote:Qr Bbpost mjk1040 wrote:Qr Bbpost Yes, your picture shows the problem, another RyLime treatment is in order with maybe a higher concentration mixture or full strength. My open cooled system wasn't over heating but producing steam. RydLime treatment cleared it up and plan on doing another treatment this season.
I agree if the one failed I would do the same thing and change them both out.
