Marine Air A/C blows breaker instantly
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Marine Air A/C blows breaker instantly
Thanks for posting the solution to your problem. Someone else down the line with the same issue will have a solution posted.
Sounds like you have some A/C experience. If the compressor failed electrically (shorted windings) as you mention. Make sure you do an acid test on the oil before installing a new compressor. If there is high acid content the new compressor wont last very long.
