Just bought a Carver have a couple issues/questions
Re: Just bought a Carver have a couple issues/questions
Also look for an in-line fuse in the power wire right by the pump. My 83 had one there, as well as a breaker on the panel.
On the fuel gauge... the switch is a temporary switch. You have to hold it to port or starboard to check the fuel level, and it gets power from ONE of the engine ignition switches. On mine it's the port engine.
Also check for an in-line fuse in the power wire right by the pump. Mine had one as well as the breaker on the panel.
On the fuel gauge. The switch is a momentary-contact switch, so you have to hold it to port or starboard to get a reading on the gauge, and it's powered by ONE of the ignition switches. Mine is powered by the Port engine ignition switch.
Post by tomschauer »
if its a 1988 27, it most likely only has a single fuel tank and a fuse panel, no breakers.
Post by RGrew176 »
Welcome Aboard. Good luck with your Santego. Hopefully your issues are few and far between.
