3607 Aft Cabin Sliding Window Felt Channel
SeaDog3807
Vessel Info: 1988 Carver 3807 Aft Cabin
Dual Helm
Dual Mercruiser 7.4 Blue Water Thunderbolt IV ignition
Direct Drives
Koehler 8.5KW Generator
Re: 3607 Aft Cabin Sliding Window Felt Channel
Post by SeaDog3807 »
Ron, can you describe, or add photos, of how you removed your salon windows on the 3807?
SeaDog3807
Dual Helm
Direct Drives
Ron, do you have photos of the removal of the windows on your 3807? Or can you describe how to do?
wbatkiewicz
Vessel Info: 1991 Carver Model 33 Aft Cabin with hard top
Post by wbatkiewicz »
Steele Rubber Products sells weather stripping in 8ft lengths, pn 70-3570-58 worked in my 1991 Model 33 aft cabin.
quickdecision
Vessel Info: Carver 3807, 1987
Been thanked: 23 times
Post by quickdecision »
Do you want to start with the aft stateroom windows?
Ron
Well, I finally got around to starting this project. Over the winter, I had ordered a roll of the snap-in stuff suggested earlier in this thread, but was unsure how easy it was going to be to get the old stuff out or the new stuff in. Yesterday I got brave and pulled out a couple of the old sections and it was FULL of dirt and decayed insect parts underneath. Took a bit to clean it out and I need to get a better brush for when I do the other sections.
You need a pair of good needle-nosed pliers to pull the old stuff out. Mine came out mostly intact but one of them broke a few times as I pulled a little too hard. Cleaning out the channel after they are out requires a stiff brush with bristles that are at least 2" long. There is also a plastic spine under the window that you can pull out to clean or replace. It snaps in place. I'd like to find a source for that, as it would be nice to replace a couple sections have been worn down.
Putting the new stuff in is much quicker than I thought. Using even smaller needle-nosed pliers, you can get the bottom edge of the new pile in the track and snap the top in place. work 3-4 inches at a time, then slide that back past the window. Keep doing that until that side is all complete.
I used to have a problem what when you hosed the windows down hard some water would leak past and into the boat. Doesn't happen with the new pile, which is nice.
I did take some pics of the work and will clean them up and post them here too.
Post by RGrew176 »
Thanks for the excellent description of how you solved your issue.
