2001 Carver 396 Prop size?
Re: 2001 Carver 396 Prop size?
Did you figure out the problem you posted back in July, or are you still working on that?
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 149 times
Not yet - still waiting on props to come back from shop since the starboard one was so out of line and vibrating. Plus, I had an exhaust leak (i.e. seawater leak) on the port engine which ended up being a major issue - two FRP exhaust tubes were significantly damaged as well as a 45deg elbow. One of the FRP pieces has to be manufactured by Centek, but it is in progress. So that engine is out of service too.Did you figure out the problem you posted back in July, or are you still working on that?
Once everything is back up and running I'll post back about that issue.
MV Verity
2002 Carver 396
2002 Carver 396
