Re: 2001 Carver 396 Prop size?
Posted: August 18th, 2022, 12:37 pm
Did you figure out the problem you posted back in July, or are you still working on that?
Discuss Carver Boats and Yachts at the best Carver Owners Forum on the net!
https://www.carveryachtowners.com/
Not yet - still waiting on props to come back from shop since the starboard one was so out of line and vibrating. Plus, I had an exhaust leak (i.e. seawater leak) on the port engine which ended up being a major issue - two FRP exhaust tubes were significantly damaged as well as a 45deg elbow. One of the FRP pieces has to be manufactured by Centek, but it is in progress. So that engine is out of service too.Did you figure out the problem you posted back in July, or are you still working on that?
