under cupboard coffee maker for 396 carver
Has thanked: 268 times
Been thanked: 1153 times
Re: under cupboard coffee maker for 396 carver
Postby Midnightsun » October 17th, 2020, 9:46 am
On my boat a Nespresso unit fits nicely along with the frother in the space after the B&D was removed. Simply slide them out, make coffee and then slide them back in. There is a dual receptacle located conveniently just in front of the coffee machine where we can plug both units in.
Jen90
Vessel Info: 1990 carver 2357 montego
Postby Jen90 » April 18th, 2021, 11:06 pm
This thing is awesome and very portable. Fits in my lunch box for work as I work for the Railroad. Brews quick and makes good hot coffee. Nothing like a cold night on a engine brewing and smelling fresh coffee. Also brewing your coffee when away from home terminal is perfect. I buy coffee beans and grind them up and jar it before every trip for the best coffee. I use #1 filters with mine for easy and quick clean up. The only downfall is the cup it comes with. Its cheap and not good at all. I ended up using a 14 ounce Yeti instead of the 14 ounce cheap cup it comes with. Ive used it several times while at work and havent had any issues at all. I highly recommend this to anybody that needs a portable coffee maker. Just upgrade your cup if you want your coffee to stay hot. The cup it comes with works! its not horrible just cheap. Good luck!
