denpooch wrote:QR_BBPOST Yea COOLER that's it.
KM its a 12 volt thruster and the two starter batteries (900 CCA) are wired in series.
OK, maybe you're getting the terms "parallel" and "series" mixed up. If two batteries are wired in series, they would total 24VDC. Now, you could hook a 12V thruster to either the first battery or the second battery, but you're not getting any advantage of the two batteries hooked together, so I'm not sure why you'd do that. If they were in parallel and the thruster was a 12VDC unit, you'd get the capacity of both batteries.
If the two batteries are really in parallel, what you'd really want is a high-capacity relay between then that is activated when you use the thruster. Then the two batteries would be isolated and be charged independently
Viper wrote:km1125 wrote:QR_BBPOST....If you're recharging them independently, then it's perfectly OK to have different battery types....
I'm not sure I'm following but I might be reading it wrong. Unless you have a very expensive charger where you can program a different battery type for each bank, or are using multiple charges, all the batteries on the boat being maintained by the same charger with multiple bank outputs should all be the same type so the (single) charge curve setting suites all the batteries hooked up to that charger.
Having said all that, what do we do about the charging characteristics when the batteries are being charged by your conventional alternators that don't have settings for different battery types?
There are smart alternator charger systems out there now that are becoming more popular due to the higher costs of some battery types but very few people upgrade this part of their charging system when upgrading to expensive batteries.
Yes, if they were different types your charger would have to be able to have independent settings for each output, or you'd have to use two chargers.
I think the issue with the alternators is just a length-of-time thing. If you were to run the same batteries on your engines for 1000 hrs, that would typically be years of usage for the average recreational boater. Plugged into and sitting on shore power, those same batteries would get that charge in a couple of months. If the charge voltage was off and what was causing the batteries to go bad, it would take years with the engines and months with the charger.
