Tireless wrote:Source of the postdarrenlife wrote:Source of the post I’m just getting myself familiar with this technology so forgive my questions if not applicable but noticed you are hoping to get 35A through a 30A controller, is this possible? Won’t the controller limit charging output/capacity to 30A?
Good luck with the installation! Chris was very helpful and was very patient to answer all of my questions.
I have he same charge controller and love the Bluetooth capability and not having to wire a separate remote, lots of data and trending available.
It was a clear, sunny day during my install and it reached about 298W input and around 22A output which seemed reasonable. I’m hoping this will give me enough to balance the draw of 18 year old fridge which runs constantly ( next project)
I haven’t measure the input current at the batteries yet but will post when I do
Good point, still trying to get my head around all of the techno stuff myself. I was told that is what the panels will produce, but I expect that the 30 Amp controller will maintain at the appropriate level. It is the Victron SmartSolar 100/30 MPPT Solar charge controller. The panels are 4 X 110W Sunpower E-Flex.
I was advised to put a 30 amp breaker between the panels, on the positive lead and the controller and they supply a 40 amp fuse to install before the battery. I am also going to put in an on/off switch beside the battery.
I am installing the controller in a cabinet in my aft deck, which is about 15' from the panels and then I am going to run 8 gauge wire to the switch, fuse and battery. I don't think I will loose anything. Chris is coming to my boat this evening to deliver the equipment and I will be going over the install with him as well. Fingers crossed.
If the set up does not give me what I am hoping for, then I will add two more panels and a second controller.
Greg
Solar panels
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
Re: Solar panels
