Gary Rose wrote:Qr Bbpost I have the same problem , mine was overheating. When it overheats it shuts down the fuel pump. I have replaced everything. Stat waterpump cooling chamber head gaskets , impeller, have burbed system several times. Still running hotter them usual and shuts off at times. Cant figure out why, looked to replace but Kolar does not make a gas genny anymore. Owens is about $12.5 good luck and let me know what you find.
You could possibly haver some impeller pieces stuck in the cooling system which would restrict flow. Might want to check that out.
Montreal, Canada Midnight Sun I Photos
You should probably start a new thread since it might get lost here. If you think it is an overheating, start by getting an infrared gun to check temperatures. Then you can see if it is the sea water side or the coolant side that is overheating. The previous poster is correct, the end cap does not come off on that heat exchanger and it is difficult to clear out debris. Broken impeller blades and zinc pieces can clog the tubes. You replaced head gaskets? That seems really extreme.
