Carver 404 / 396 ease of maintenance
Has thanked: 324 times
Been thanked: 595 times
Re: Carver 404 / 396 ease of maintenance
Postby tomschauer » October 27th, 2020, 8:26 am
My stairs do lift out for access to the starboard trans.
MSC
Vessel Info: Shopping for a Carver 405 or 406
Postby MSC » October 27th, 2020, 8:29 am
Thanks tomschauer, for the details on the 355/356. They have the same engine room as the 404 which I really like, but I do not think that I would want to try getting around the two diesel engines in those two models. I have noticed that the location of the generator must make life even more difficult.
Removing a heat exchanger to change a pump impeller will be starting to test my patience level, I think.
Been thanked: 261 times
Postby buster53 » October 27th, 2020, 8:50 am
MSC wrote:Source of the post Thanks tomschauer, for the details on the 355/356. They have the same engine room as the 404 which I really like, but I do not think that I would want to try getting around the two diesel engines in those two models. I have noticed that the location of the generator must make life even more difficult.
Yes, a big, burly mechanic won't be able to squeeze into the engine room forward of the starboard engine, but someone a little smaller can. During our survey, we had to have the starboard impeller replaced and the mechanic crawled in and took care of it pretty quickly.
We have a young kid at our marina who does some service work and I'm sure he could easily get in there.
Me...ain't happening. I think I'm just a little too big, but more importantly, at 67, my body just doesn't bend like it used to.
Postby buster53 » October 27th, 2020, 8:57 am
tomschauer wrote:Source of the post My stairs do lift out for access to the starboard trans.
Anything special you have to do to move them? I looked at mine and I couldn't see anyway to move them. Maybe I need to look harder.
Postby tomschauer » October 27th, 2020, 10:22 am
There are four screws that hold the aft cabin stairs in place. You have to feel around in the carpet to find them. Once removed the stairs easily tilt back and lift out.
Not sure what engines you have. I have Merc 7.4's. There is exactly 10" between the heat exchanger and the bulkhead under the dinette to get down in front of the engine. I'm a little thick in the middle,(5'10' 185) but not much, no way I can fit.
If the genny wasn't mounted in the middle forward of the engines, I could get in from the side instead of above without removing the heat exchanger.
Postby buster53 » October 27th, 2020, 1:00 pm
tomschauer wrote:There are four screws that hold the aft cabin stairs in place. You have to feel around in the carpet to find them. Once removed the stairs easily tilt back and lift out.
Good to know. Thanks.
BTW, I have Crusader 8.1's, so maybe a different configuration from your Merc 7.4's.
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » October 27th, 2020, 7:04 pm
Take a look behind the tranny opposite the stairs. If I remember correctly, when they're removable, you'll see some framing on the bulkhead otherwise it'll just look like one solid molded piece covered with insulation. Tom can confirm.
Users browsing this forum: No registered users and 70 guests
