Kohler generator
- KeithS
- Vessel Info: 2005 38SS
- Been thanked: 23 times
Re: Kohler generator
What are you using to check the speed? I find the easiest way is the frequency since my voltmeter is already connected.
- KeithS
What are you using to check the speed? I usually use frequency since my voltmeter is already connected. RPM is difficult on that model because of the waste spark system, it is firing every revolution and gives false rpm readings.
- jisster1
- Vessel Info: 1990 Carver Santego640
- jisster1
Also it's not a little bit of RPM's that make it produce voltage. Going by ear I would say I need to get it up to about 4000 to 4500 rpm's to get 120 out of it
You need a good DVM with a frequency ( HZ ) function available.
- Been thanked: 654 times
As mentioned many better dvms have frequency but also you could use other plug in items like the (kill a watt meters) that also read frequency or cheaper version similar to this if you don't want to spend more for another multimeter....https://www.ebay.com/itm/Digital-Power- ... 890.l49292
I'm glad you clarified this. I was stumped when you said "high idle" and was wondering if you were slowing the engine down from normal speed to get the voltage.
Does this model have brushes? Could you have a worn brush not allowing current to get to the field?
- jisster1
No it's a brushless generator. I tried again tonight and again if if run the motor at about a half throttle or more I can get 110 volts if I throttle it higher it will put out more volts the minute I let it idle I get only 8 volts.
Sounds like maybe you have a governor problem. I would get a tach for a 2 cylinder engine and make sure where you are with the RPM. It really should never "idle". It should always be about 3600 rpm. The governor assembly and spring open the throttle further under load to keep it at 3600+/-.
- jisster1
It's not a governor problem. I know what a high rpm is. When I rev it up to get volts out of it, it's at least 4000 rpm's to 5000 rpm's. It should not have to run at a high rpm to get power.
