Size and number of duck bills
Has thanked: 455 times
Been thanked: 1671 times
Re: Size and number of duck bills
Postby Viper » February 17th, 2021, 8:50 pm
Ya the VG4 is the J style pump that takes 2" valves. The VG2 is the pump we're all used to seeing more of (S series) which takes the 1-1/2" valves. Depending on the setup, the S series might be mounted on top of the tank or completely separate of the tank. The J series would always be mounted to the tank as it becomes an integral part of it.
tgebler
Vessel Info: 2000 396 AC
Has thanked: 5 times
Been thanked: 23 times
Postby tgebler » February 18th, 2021, 5:07 pm
Thanks. You are clearly the marine sanitation guru on this site. I have learned alot.
Postby Viper » February 18th, 2021, 7:00 pm
No I stink at that ;-)
thatchh
Vessel Info: 2004 Carver 396ES gas Crusader 8.1
Been thanked: 10 times
Postby thatchh » February 19th, 2021, 4:53 am
I have a 2004 396 aft cabin. My two vacuflush pumps have small tanks separate from the main holding tanks, and they each take 4 1 1/2" duckbills. There should be no other pumps, unless you have overboard discharge pumps. Those would not affect your toilet flushing as previously stated. I have added a couple of pictures of my pumps in case it jogs your memory. They are the same for and aft. The forward pic is not very clear. I was actually taking a picture of something else at the time. It's possible if you have your Carver manual with the bill of materials, that it might tell you what units you have. There is a separate list in my manual for items with serial numbers.
tgebler
Postby tgebler » February 19th, 2021, 9:40 am
Thanks, I have ordered the valves and will give it a go when the weather gets warmer. I figure sicne it is a dirty job, I may as well make all the changes at one time. I do have two discharge pumps.
Postby Viper » February 19th, 2021, 10:03 am
Remember you're working with bio hazardous waste, it can be dangerous. Put on a couple of layers of good nitrile gloves and you should be wearing full face protection in case anything sprays out while you're doing this, which can happen under certain conditions. Have a ton of rags on hand and a bucket or bag to put them in. Spread a bunch of rags under the fittings before you undo them. Unthread the fittings slowly to release any pressure that might be there and allow any vacuum to equalize to atmosphere. There shouldn't be too much in there when you open it up unless there's a problem but it pays to be prepared.
I lightly lubricate the base of the valves so they slide a bit when you're tightening the fittings back together. I find that if you install them dry, they catch and twist inside the fitting. This causes them to distort and open up which will cause the system to leak. When that happens, you'll think that since you just replaced the valves the leak must be elsewhere and spend an eternity trying to find one that doesn't exist. Dish soap works fine.
Oh and don't forget a clothes pin.....for your nose ;-)
Good luck
tgebler
Postby tgebler » February 19th, 2021, 11:18 am
Thanks!!
Users browsing this forum: No registered users and 96 guests
