Moving & removing the top
Catanae
Re: Moving & removing the top
Post by Catanae »
Hey, I'm in an identical situation. And I don't have anyone to help me, and I was thinking of turning to the pros. Can anyone recommend a company?
boh50
Post by boh50 »
Hey there,
I've moved my boat before, and it's definitely a challenging task. Removing the top yourself can be tricky, especially if you're not familiar with the process. It involves carefully detaching the hardware, wiring, and any other components. You need to ensure everything is labeled and organized to reassemble it correctly later. I found that getting the top off was time-consuming and required a lot of patience, particularly with all the small parts and fittings.
A friend recommended a good moving company to me, and they were a lifesaver. They had the expertise and equipment to handle the top removal and reinstallation, making the entire move much smoother. If you find the process overwhelming, I’d suggest looking into professional help. It really eased the stress for me and ensured everything was done correctly.
